Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 12-31-2005, 07:17 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Dyno results
I haven't posted in here in a while. But this will prolly help some of you out in terms of setup selection.
Lately I have been on a bit of an "efficiency" trip. Trying to maximize power without turning up the boost. I think I did a pretty decent job here.
That is at .85-.87kg/cm2(12psi)
That is at .5kg/cm2(7psi)
My setup:
GroundZero manifold
Garrett T3/T04E 50trim w/.63ar turbine housing
Turbonetics evolution 35mm wastegate
3" custom downpipe made by me
TurboXS Type RFL Blow Off valve
Boostdesigns intercooler kit
Enthalpy Tuned ECU
615cc injectors
300zx MAFS
Apexi power intake
Apexi SAFC
Apexi AVC-R
Apexi N1 exhaust
IAP oil line kit
MSD SS blaster coil w/ my rewiring mod (http://www.ka-t.org/ignitionrewire.htm )
ACT heavy duty pressure plate with organic disk
NGK BKR7E-11 plugs
Magnecor plug wires
Walbro 255lph fuel pump rewired (http://www.ka-t.org/walbrorewire.htm)
S14 seat
Stripped trunk
My Overboost protector ( http://www.ka-t.org/overboost.htm )
Yea as you can see, that downpipe was FUN to make! LOL I had to weld that with a AC current stick welder to add to the fun. 304l isn't too stick welder friendly. I basically spent 3 hours doing tack welds to weld it together to control heat.
Installing the manifold was very easy. Turbo/manifold made it in the car within 2 hours. That is including taking out the old setup.
But yea, the old setup was trash compared to my new stuff. Old setup was:
Revhard log manifold
T04B .60ar T5/T6 trim/.69ar on center housing w/P-Trim wheel.
The only thing I liked about that setup was that P-Trim wheel.haha
Either way, I just thought I woudl share how much a tubular manifold and tangenal turbine housing along with an effiecent turbo for your engine can do! Most turbo'd KAs make 290whp at 12psi. A friend of mine with T04E 57trim, revhard, and JWT cams made 310 uncorrected WHP. His cams are 256/256 and mine are 242/248 duration. Lift is close to the same.
Enjoy
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 12-31-2005, 09:22 PM
Black Lotus's Avatar
Black Lotus Black Lotus is offline
That's seems like really good power for that little guy.
Kudos to you!
The engine seems almost peaky 'tho, why is that?
Cam timing?
Old 12-31-2005, 10:47 PM
240SX Guy
Re: Dyno results
It does? I make over 290ft/lbs of torque for almost a 2000rpm range and I make over 300whp for a 1000rpm range. I thought it was a rather broad power range.... Not large displacement broad, but still not bad...
More than anything, in that run, I needed to pull fuel before 5000rpm which I now do. It could use a lot more timing too in some areas.
BTW for anyone who doesn't know, this is on a 2.4liter engine. Bore=89mm, stroke=98mm.
-Cory
12.6@122mph
Old 12-31-2005, 11:20 PM
Yeah, you're right. I was thinking of something else, then comparing the apples vs. the oranges in my head.
I'll bet it's fun in the rain, heh heh.
Happy New Year!
Time to bail.
Old 01-01-2006, 12:12 AM
240SX Guy
Re: Dyno results
Its fun all the time.. Esp at 14psi.
-Cory
12.6@122mph
