Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 12-31-2005, 05:41 PM
nvmyvettes nvmyvettes is offline
locate trans sol kit
I am sure my shifting problems are related to solenoids thanks to posts on this site, and answers to my previous posts. Thanks again doldsmobile. Now if I could bother you or any one one more time,where can I find the kit that several referred to that includes both solenoids,gaskets, filter,etc...
Old 12-31-2005, 05:44 PM
Re: locate trans sol kit
boldsmobile sorry
Old 12-31-2005, 09:13 PM
boldsmobile boldsmobile is offline
Re: Re: locate trans sol kit
I bought my kit at the local ac delco supplier.
Use this thread for more info:
http://www.automotiveforums.com/vbul...d.php?t=168531
The gasket for the lower pan may or may not come with the filter kit. Some suppliers only you give a filter with their kits.
You'll need:
Solenoid Kit
~10-11 quarts of fluid. I am think you are Dex III but you should verify.
Both lower filters - yes 2 in there.
Lower Pan gasket.
Jack
Two jack stands
Drain pan
10mm socket
DONT LOSE THE 4 CHECK BALLS. Look on the cadillac forums (sts i think) for diagram and description of where they go.
Peter Ferraro
1998 Bravada
1996 Aurora
1971 Cutlass
Old 01-04-2006, 07:58 PM
kiway22 kiway22 is offline
Send a message via Yahoo to kiway22
Re: Re: Re: locate trans sol kit
Please read the following thread. It will also direct you to another thread that will take you to a diagram of the solnoids.http://www.automotiveforums.com/vbul...d.php?t=168531
