Old 12-31-2005, 04:19 PM
marly87 marly87 is offline
Need a quick answer! '96 Blazer LS Oil Leak
I'm on my way to the parts store, so I need an answer lightning quick! I have an oil leak on my '96 Blazer and was wondering if a bottle of "Stop Engine Leak" would help my car until I can get it to the shop next week?
Old 12-31-2005, 05:32 PM
jsgold jsgold is offline
Most of the time it is a waste of money. If you have a very small leak from an old seal, using this or heavier oil might slow it down but not stop it, and heavier oil is not advised. You may have the same problem as me with leaky oil filter lines. Not aware of anything that will stop that except replacement.
I used to be indecisive, now I am not so sure.
Old 12-31-2005, 05:56 PM
LTBlazer97 LTBlazer97 is offline
Send a message via AIM to LTBlazer97
Re: Need a quick answer! '96 Blazer LS Oil Leak
Yeah, in my opinion its a snake oil. Do you have any idea where the leak is eminating from? Maybee a recent repair, or oil change? Not to insult intellegence, but If you havent allready, One thing that could help you eliminate a problem, is if the drain plug is loose, and even the Oil filter is loose and not sealed properly. Just a thought, good luck.
Old 01-01-2006, 12:08 AM
OverBoardProject OverBoardProject is offline
Banned
If your reffering to that really thick additive that looks like honey then it actually works for a short term fix.
When I first got a 63 Ford 1/2 ton I used it to get around until the re-build kit got in.
If you use it though consider doing an engine flush when you get it fixxed and change the oil and filter.
Old 01-01-2006, 05:52 PM
Cool Re: Re: Need a quick answer! '96 Blazer LS Oil Leak
Thanks, guys. I didn't get it. Since I don't know where the leak is coming from, I figured it would be a waste of money.
