Old 12-31-2005, 04:03 PM
hockeyguy hockeyguy is offline
89 GP idles bad
I have a 89 Grand prix with a 2.8 that idles bad after warm up.
SES on, stored code is a 45 (too rich). I have replaced the TPS and the O2 sensor. I have unplugged the vapor canister but I can't seam to find the canister control purge valve and cleaned the IAC and the housing for the IAC, none of these things has helped. The engine idles normally on start up but you can smell that it is running rich and after warm up (when the computer is adjusting for the rich mixture) that is when the idle starts to fluctuate from 1000 down to 500 RPMs.
I am banging my
Please help!!!
Old 12-31-2005, 05:39 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 89 GP idles bad
Welcome to AF!
Start with cleaning the EGR valve and the passageways to the plenum. Since it idles and runs rich when it is warm this may be bad and causing it to run rich. 2. Clean the idle air control valve and passageway on the throttle body. This will cause idle problems if the IAC isn't working correctly. 3. Check the map sensor since it can cause issues and finally you may want to replace the O2 sensor. It sends signals to the ecm to tell it how much gas to send into the engine. If it is bad this will cause poor fuel economy and a rich condition.
Old 01-01-2006, 12:02 AM
Re: Re: 89 GP idles bad
Originally Posted by GTP Dad
Welcome to AF!
It is running rich from start up. where is the map sensor??
Old 01-01-2006, 05:07 PM
Pontiac Guy
Re: 89 GP idles bad
Look on the firewall. Should be held in place with two bolts have an electrical connector and a vacuum line connected to it.
Old 01-01-2006, 06:51 PM
I have 2 of those boxes mounted on a bracket. One of them has 1 hose and the other has 2 hoses could one of these be the canister purge valve??
I really appreciate your help.
Old 01-02-2006, 08:11 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 89 GP idles bad
If you're talking about the bracket on the back of the intake, the one with one vacuum line is the MAP sensor, the other is the vapor canister purge solenoid. I agree with GTP that the problem is probably EGR related, but that valve is EXPENSIVE (about $175), so I don't blame you for exploring other avenues..
Old 01-07-2006, 06:57 PM
Ok I replaced the map and fixed the vacuum hose to the MAP but that line had fuel in it. I also have fuel in one of the 4 vacuum lines going to the throttle body coming from the fuel pressure regulator, this is a "T" line that goes to the MAP.
Could a bad fuel pressure regulator be cause my bad idle problem???
Old 01-07-2006, 06:59 PM
maxwedge maxwedge is offline
A990 racer
Re: 89 GP idles bad
Certainly if you have fuel in the hose off the regulator it is leaking, this may or may not be the problem but fix it.
Old 01-07-2006, 07:03 PM
Old 01-08-2006, 10:45 AM
Pontiac Guy
Re: 89 GP idles bad
Yes it could! Especially if you are sucking gas into the vacuum lines. The fuel pressure regulator regulates the amount of fuel pressure to the injectors if the pressure it too low it would cause the idle to be bad. You still should clean the IAC and passageways once you change the fpr.
Old 01-09-2006, 11:51 AM
richtazz's Avatar
Re: 89 GP idles bad
Get that FPR fixed soon. That is your problem and it will only get worse. If the raw fuel backs up the vacuum lines, it can damage other vacuum controlled devices, causing more problems and more headaches.
Old 01-15-2006, 02:05 PM
Thumbs up Re: 89 GP idles bad
Thanks guys for all the help.
My problem was the fuel pressure regulator.
Does anyone know how to get the steering colum cover off??
My low beams don't work and I have to pull the turn signal lever towards me to get them to blink.
Thanks again
