Old 12-31-2005, 12:10 PM
redmoparracing redmoparracing is offline
Question 92GT3000VR4 Several Issues with car
HI
I am new to this forum and also just purchased a 92 GT3000 VR4. I have several questions and any help greatly appreciatted.
1. any good service manuals out there and or owners manuals.
2. Right hand fog light replacement bulb and how to get to it to change it.
3. sport tour switch broken and need a replacement and how to change it.
4. The exaust pipe that connects the 2 banks is rusted out at the first flex joint and what would best replacement be for it.
5. More power needed! Best cheapest way to achieve this?
6. what is the normal boost on turbos for these. My gauge reads up to the top 14psi is this right for stock or is the gauge off or has it been modified. (what to look for.
I guess I have a lot more questions than I thought but any help greatly appreciated.
Old 12-31-2005, 03:11 PM
Morphius289's Avatar
Morphius289 Morphius289 is offline
Re: 92GT3000VR4 Several Issues with car
There should be an automated FAQ machine that would post FAQ on posts that should be referred to it.
(check the FAQ )
Black 1997 3000GT
Originally Posted by Igovert500
[01:05] Igovert500: scrwe his method
[01:05] Igovert500: too much crap
[01:06] Igovert500: i just jam a garden hose in there
[01:06] Igovert500: and put it on high flow
[01:06] Igovert500: go the opposite direction too
[01:06] Igovert500: so it clears out more shit
18 and out of debt - member #1
Old 12-31-2005, 07:36 PM
xXxRocker5150's Avatar
xXxRocker5150 xXxRocker5150 is offline
Send a message via AIM to xXxRocker5150
we already do, and his name is Geoff
Georgey on the subject of midget beastiality pornos
Originally Posted by 1viadrft
I've seen a video or two out of curiousity.... those damn midgets are hung! But then the donkey walks in...
Home Puta's 4Life Crew Member #1
R.I.P Andy, you will be missed by all.
Old 12-31-2005, 07:37 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Originally Posted by redmoparracing
HI
the FAQ has most of the answers to your questions, but i'll see what i can answer off the top of my head:
1. Service manuals--> YES! you can purchase them in book form from www.3sxperformance.com for nothing cheap, but what i would recommend is the manual on cd. it can be found at www.manualcd.com--> 3/S Manual 'backup' CD. much cheaper, around 20 bucks i think. great resource.
2. fog light replacement--> H3 bulb. can be found at most hardware/local auto parts store for a few bucks. to remove fog light, access from underneath front bumper, disconnect fog light, remove 3 bolts, remove fog light. remove back cover of fog light housing. NOTE: bulb is held in by crimped metal connectors. NOTE 2: since you have a VR4, you might have to remove the front active aero dam underneath the front bumper to access the fog lights.
3. broken switch? --> you can find a replacement at the parts for sale section of 3si.org (http://www.3si.org/forum/forumdisplay.php?f=4). to remove, it simply pops out from the dash. use a flat head screwdriver to pop it out.
before you buy a new switch, make sure its the swith that's broken.
is the the Sport/Tour switch for the EXHAUST or SHOCKS?
4. your downpipe is rusted in several places--> a good replacement would be one sold at www.3sxperformance.com. the one they sell improves the exhaust gas flow.
5. more power?--> FAQ has good suggestions for this. turn up boost, stock turbos hold only 10/12 psi to redline. upgrade turbos. upgrade fuel. get a frount mount intercooler. etc etc.
6. normal or stock boost for the 91-93 cars is 7psi, i believe. someone may correct me on that.
Welcome to AF.com. the FAQ thread is a great resource, also the Search feature is very helpful. if you want to find out more, www.3si.org is a great place for researching the 3/S cars.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 01-01-2006, 10:14 AM
Thanks for the help and I will check the FAQ. New to this so thanks for any help.
Old 01-02-2006, 10:26 PM
Igovert500's Avatar
blue + red light magnet
Re: Re: 92GT3000VR4 Several Issues with car
Oh and as far as boost numbers. That gauge is a plastic POS, it doesn't measure boost, it measures load and other factors via the ECU and kinda guesses. The real numbers are somewhere in the range of 91-93s 9-11psi, 94-99s 10-12psi...give or take.
Check out the part in the FAQ on 'free boost mod'...you'll like it
Then check out the mod guides as well.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 01-03-2006, 06:46 AM
thanks . I have been reading up on these items and looks like there is a lot of good info here and links. great site. and i repeat thanks for any and all comments.
Old 01-04-2006, 04:40 PM
ChrisGood's Avatar
ChrisGood ChrisGood is offline
as well you should hit some of the other sites, welcome newb, and why is it instead of just typing out the answer or posting a link to the answer people would rather rant "why dont you search or check the FAQ's"
I can fix anything, if you just tell me how.
White 2006 Chrysler Town & Country
Zurich Pearl White 1993 3000GT VR4
1993 3000GT VR4
Old 01-07-2006, 11:53 AM
Igovert500's Avatar
Honestly, because many of us spent many many hours writing that thing. We did it because every week we were spending many hours writing the same replies to the same questions over and over and over again, because nobody used the search button.
I have no problem answering questions, that is how we learn. I do have problems with people not putting forth an ounce of effort to find the answer for their question when it is 2 seconds away from them.
So to save myself and others time, we wrote the FAQ. Now instead of answering 20 identical questions a week, we can simply say "refer to FAQ" and not waste our time.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
