Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 12-31-2005, 09:03 AM
mrlakemary mrlakemary is offline
Passenger seat tilt problem
I have a 2003 wrangrler sport and am having a problem with my passenger eat not tilting forward. The seat moves back and forth just fine but does not raise to tilt forward which makes access to rear seat difficult. Everything "looks" to be ok - nothing obvious to be wrong. Fell may be locked up (some rust) and tried WD40 with no luck - just won't even budge. Any ideas on troubleshooting or how to fix would be greatly appreciated.....
Old 01-01-2006, 10:46 PM
oljeeptek oljeeptek is offline
Re: Passenger seat tilt problem
Pull it out, flip it over and see if you can manually release the catch. You can take the cover or upholstry loose to see what's nit going on.
Remember...
Old Jeeps never die, they just sometimes look that way!
Old 01-03-2006, 08:56 AM
JEEP1997 JEEP1997 is offline
Send a message via AIM to JEEP1997 Send a message via Yahoo to JEEP1997
not to insult anyone, are you pressing down on the release under the seat PRIOR to trying to tilt it forward?
Old 01-04-2006, 08:04 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
The '03 has the pull strap on the outboard side of the psgr seat, right? I've found that one smooth, brisk pull will bring the seat forward.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 08-18-2009, 02:33 PM
flyboylance flyboylance is offline
I am running into the same problem, but how do you take the seat out without flipping it forward?
Old 08-24-2009, 11:50 PM
4x4grey88's Avatar
4x4grey88 4x4grey88 is offline
You should be able to remove it by removing the bolts that hold it down. The seat moves forward and backwards to get to the bolts. You will need a hex and combination wrench.
Remove the seat and look on the under side.
I tried to insert pics but upload errors
www.jeepforum.com; www.socalultimate4x4.com
1998 Wrangler (replaced my 88 XJ)
21' Mini Winnie (replaced my Pace Arrow)
