Old 12-31-2005, 03:45 AM
hany's Avatar
hany hany is offline
turbo boost
what is turbo boost and where it install adjust ?
MY ENGLISH IS NOT PERFECT. sorry for that
1992 CIVIC 4DOOR ULTRA BLUE TURBO -SOLD
1996 CIVIC 4DOOR EUROPIAN VTEC LS
2003 CIVIC LXI
1999 GOLF 4 1400 CC
Old 12-31-2005, 11:01 AM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: turbo boost
What are you talking about? Are you asking what the boost of a turbo is, or is Turbo Boost some product that I've never heard of?
Old 01-01-2006, 04:19 AM
hany's Avatar
Re: Re: turbo boost
my info in the turbo is poor and i will install turbo in my d15b vtec i bought the turbocharger and the pipes and the intercooler with its pipe.
then i heard about turbo boost controler i think it control on the pressure of the turbo not to damage the engin is not ? and where it install at the turbo kit in which part adjust ( or it is many kind and many places to install ? ) and does it need guagge ? and any guagge bolt in it ?
2003 CIVIC LXI
1999 GOLF 4 1400 CC
Old 01-01-2006, 11:30 AM
CivicSpoon's Avatar
There is no Spoon
Re: turbo boost
The boost controllers are connected to the wastegate. It will open the wastegate at a certain psi, and limit the amount of psi (boost) that goes into the engine. You'll definently need a boost gauge, so you know how many psi you're running.
But do NOT do anything until you know exactly what you're doing. Things can easily go wrong with forced induction. Do a ton of research beforehand. Start here: http://www.automotiveforums.com/vbul...d.php?t=490574
Old 01-02-2006, 05:32 AM
hany's Avatar
Re: Re: turbo boost
thanks alot for your info. i will read and if i have a problem i will mail you
2003 CIVIC LXI
1999 GOLF 4 1400 CC
Old 01-02-2006, 01:33 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: turbo boost
can you post a list of your parts and possibly some pics....what are your goals for the turbo? What are you using for fuel management? Do you have a new clutch?
We need some details on this....
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 01-02-2006, 05:12 PM
hany's Avatar
Re: Re: turbo boost
i bought a turbo and intrcooler kits from ssautochorm and the list iclude : MANIFOLD
TURBO
WASTEGATE
DOWNPIPE
90 DEGREE ELBOW
FLANGES
GASKETS
FLANGE FOR BOV
FLANGE KIT FOR WASTEGATE
INTERCOOLER ( SUPER THICK 90MM !!! ) ( NOT 70MM LIKE EVERYONE ELSE )
COMPLETE PIPING
T3/T4 TURBO INFO ( D ) SERIES
TURBO
BRAND NEW IN THE BOX
3" INLET DIAMETER
2" OUTLET
WET FLOATING BEARINGS
1/8 NPT OIL INLET
T3 / T4 FOOTPRINT OK !!
SPECS:
.50 A/R / .63 HOT SIDE
STAGE III WHEEL
TURBONETICS CAST HOUSING
BALANCED AND BLUEPRINTED AND COMPRESSION TESTED
WASTEGATE
38MM - YOUR CHOICE
FLANGES INCLUDED
BARBS AND FITTINGS INCLUDED
GASKETS INCLUDED
INTERCOOLER KIT
Greddy Style Intercooler and COMPLETE CHARGE PIPE SET
Includes all charge pipes, and Intake as well.
- so what is the rest to compelet my kis ?
2003 CIVIC LXI
1999 GOLF 4 1400 CC
Old 01-02-2006, 06:06 PM
Schister66's Avatar
AF -Advisor
Re: turbo boost
a clutch, fuel injectors, and fuel management......people also don't take too kindly to SSAC, but let us know how it works for you....
Old 01-03-2006, 02:15 AM
hany's Avatar
Re: Re: turbo boost
note
: my english not perfect and iam from EGYPT . and i did not recive the kits yet.
my engine is the d15b vtec jdm and i use the si tranny and i will buy cluch and disc cluch . i have ecu p08 and i will buy p28 because it give more fuel. and in egypt i use fuel gas 90 octain. that what i did for now .
i read your theard and it is great info for everybody to know if he at the right line. and in my opinoin it is a furten.
2003 CIVIC LXI
1999 GOLF 4 1400 CC
Old 01-25-2006, 05:01 AM
hany's Avatar
Re: turbo boost
i got the kit now but i dont have a instruction booklet. so can you help me how can i install it right? and it well be better if by pictures.
2003 CIVIC LXI
1999 GOLF 4 1400 CC
