Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 12-31-2005, 02:16 AM
flip888 flip888 is offline
Breaks Dont Work Properly
I searched but didn't find anything, but I have a 1990 gt and ever since I put the cam in the breaks have sucked, but just today they did something totally fucked up. I was coming up to a 4-way stop and when I went to press the break pedal, it went to the floor all the way, then came up slowly (when I lifted up my foot), and then the next time I pressed it it was a lot harder to press the pedal down (it didn't go to the floor this time) but I didn't get any stopping power until I pumped them a couple more times. And when they did start to work, they were very very week.
This is the worst time too because i just got a new job. I figure I need a new master cylinder or new break lines or something. I dint know much about breaks though.
Any help would be extremely appreciated.
Thanks
Old 12-31-2005, 11:04 AM
DurangoDave DurangoDave is offline
Re: Breaks Dont Work Properly
What you've described USUALLY means bad seals in the brake master cylinder.
Dave
Westminster, MD USA
Old 02-05-2006, 04:24 PM
motorjock205's Avatar
motorjock205 motorjock205 is offline
Send a message via MSN to motorjock205
Just guessing, but you say you installed a new cam...quite possibly you've installed a cam that does not allow the engine to build up enough vacuum to run the power brake boster any more.
Forget World Peace, Visualize Using Your Turn Signals!!!
Carl W. Ervin
2008 Shelby GT CSM 08SGT0235
Old 02-06-2006, 12:59 AM
mechhound mechhound is offline
Dave
Westminster, MD USA
I agree. One other possibility, there is an external leak under the car. IF there is an external leak you would have a lower brake fluid level in your master cylinder and would soon be completely out of brake fluid and have no brakes whatsoever. Whatever it is be safe and fix it as soon as possible.
Old 07-09-2006, 12:10 PM
87Stang's Avatar
87Stang 87Stang is offline
I agree. Sounds like its time for a vacuum pump!
Old 07-09-2006, 01:08 PM
351wStang's Avatar
351wStang 351wStang is offline
Hows the brake fluid level? What are the specs for the cam you installed?
1969 Cougar
357w & TKO - 475hp
Old 07-09-2006, 01:49 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Holy old thread, lets try and keep things a little more current, like with in the past 3 months.
Thanks, Craig.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Closed Thread
