Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 12-30-2005, 10:31 PM
Cymbaline Cymbaline is offline
Exclamation Tail and Dash lights won't work
I need some help figuring out a problem for my '94 Grand Marq. The tails, dash, and the yellow front lights have stopped working (I can rig them to work by pulling the switch out and slowly pushing it in about halfway, but after awhile they start to blink). At first we thought it was the switch and had that replaced - worked fine for about six months then started doing it again. Was going to replace the switch again until we found that the relay had been burnt up - so we replaced the relay and now it has burned up again - any idea as to what would be causing this wire to run so much voltage? If it's a grounding issue, is it a positive or negative ground (red and orange wires)? Could it have anything to do with the Alpine stereo that was installed shortly before we purchased the vehicle? Any insight to this problem would be greatly appreciated. Thanks!
Old 02-01-2006, 02:07 PM
Marquis_driver89 Marquis_driver89 is offline
Re: Tail and Dash lights won't work
im no good with electronics i always think its a fuse but it could be wiring
Old 02-02-2006, 12:31 AM
Stevo2's Avatar
Stevo2 Stevo2 is offline
Specifically what relay and where is it burned?
The switch you replaced was the multi-function switch on the steering column?
The stereo that was installed...how many watts and any BIG amplifier?
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
Old 05-30-2006, 08:53 PM
jason1973tl jason1973tl is offline
I can tell you exactly why they don't work. My car had the exact same problem and the lights worked if I did the exact same thing. I tried replacing the headlight switch located behind the dashboard. It only worked for a short time though. I found out that the wiring connector that plugs in to the switch had burned out one of the wires that goes to the wiring connector. Try putting a new push connector on the bad wire. Be sure to cut the wire up far enough to get a good part of the wire. You should be able to pull the dash apart and wiggle each connector individually to determine which one has the short in it. Mine was bad enough I could visually see which one was bad. Hope this helps a little, I know I was frustrated as hell. The headlight switch sells for just over a hundred dollars in case you were wondering.
The Following User Says Thank You to jason1973tl For This Useful Post:
stream (08-26-2018)
