Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 12-30-2005, 09:32 PM
beebe75 beebe75 is offline
94 cherokee 5.2L hard start when cold
My 94 jeep Grand Cherokee is hard to start only when it gets cold out
starts fine when its warm???
Old 12-31-2005, 05:21 PM
oljeeptek oljeeptek is offline
Re: 94 cherokee 5.2L hard start when cold
You need to be more specific for any usefull replies.
Are you talking about starter related( won't crank, could be battery related), or cranks but won't fire up( could be related to low fuel pressure, coolant sensor, pcm etc.)?
Remember...
Old Jeeps never die, they just sometimes look that way!
Old 01-06-2006, 02:34 PM
cranks fine will not fire up when cold outside
fires right up when warm outside????
replaced coolant sensor did not help
Old 03-06-2006, 09:55 AM
flykr2s flykr2s is offline
I have fought this problem for almost a year. I replaced every sensor possible on the car. I replaced all plug wires, dist cap, rotor, and everything else you can think of only to have the problem continue and it was worse in cold weather. Well I finally decided to replace the coil even though it checked out ok. That was the problem. Now my 93 JGC Laredo starts immediately and runs better than it has for years. Maybe I can get another 235K miles out of it. Tip of the day: REPLACE THE COIL.
