Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 12-30-2005, 08:33 PM
jpinthekeys jpinthekeys is offline
cougar vibration
I was wondering if anyone can confirm my vibration problem with my 95 cougar. The steering vibrates noticeably at lower speeds, I dont notice it at higher speeds and only when I appy the brake. I am thinking maybe ball joints or tie rod ends, It has 48000 miles, does not seem like enough to wear them out but it has been in florida for 4 years. Thanks if you can help----John
Old 01-04-2006, 10:58 AM
JR Tigerstar's Avatar
JR Tigerstar JR Tigerstar is offline
Sounds like warped brake rotors.
You can have them resurfaced but the vibration will return.
New brake rotors & pads is what you need.
Old 01-08-2006, 09:35 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
i just got done having a very similar problem on my wifes cougar, with me, the steering wheel rapidly moved back and forth while driving, it did it really bad when going slow, then the faster the car went, the less it moved back and forth, but as the car got faster, the shaking of the steering wheel got worse, also, when pressing on the brakes it pulled to the left, it turns out it was just a front tire, i guess from being so old, a belt broke inside the tire, which caused a lump on the tread to form, after having the old tires looked at it turns out both of them had lumps, got 2 new tires and it drives like new
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
