93 transsport 3.8L - Throttle Position sensor
Here are the symptoms....
Van starts and idles ok, but when I get up to hiway speeds, the check engine light comes on and I lose power. Dumping the codes I got 21 and 22, both related to the TPS. what i would like to do.... I have purchased a new TPS and would like to install it. The problem is, the two small screws that hold the TPS in place are in the most awkward location. I know it can be done if I remove the throttle body, but I was hoping to avoid this out of fear of creating more problems. I am hoping that someone out there has done this before and can tell me the "trick" to doing this painlessly. I have the the service manual but it does not cover TPS replacement. any help would be greatly appreciated. |
Re: 93 transsport 3.8L - Throttle Position sensor
Removing the throtle body is no risk and I did it once to clean the MAF sensor hot wire that had accumulated some clay and responded very slowly ....but I have also removed the TPS once without the throttle body. I used pliers from the side to loosen the screws and after less than one turn executed bit by bit , both came off easily. I think they had to stay with the TPS while I removed the unit. installing it back was done similarly. Position something under to avoid loosing the screws.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629 I don't believe in miracles. |
Re: Re: 93 transsport 3.8L - Throttle Position sensor
Thanks again |
I did not replace anything nor use silicone.
BTW, I paid a look to TPS on my car and it made me remember that I used a short screwdriver bit --that I worked with the pliers-- to loosen the far side screw....that was several years ago. Honest, I think it is more simple to take that throttle body out.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629 I don't believe in miracles. Last edited by LMP; 12-31-2005 at 01:27 PM. |
How the heck do you get the throttle body off? I removed all the nuts (4) that i saw/felt and the thing felt like it was still attached. Is there another bracket or nut? Thanks
I guess I must have used some polite hammer blow with a piece of wood between hammer and body to unstick the gasket....
www.avigex.ca/xport/throttlebody.jpg
, but I remeber having problems removing throttle body.
Thanks... I seen the double nut but it just spun on the other side... I got got it off fairly easy by removing the thermostat housing and unloosened the screws with vise grips...
