Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-30-2005, 06:16 PM
knotters2006 knotters2006 is offline
engine problem
have an 1995 eagle talon esi , 148,000 miles, when i start it up it will idle fine , then when it gets to normal operating temp , it will start running bad , have put over 300 dollars just to find out what is wrong , can anyone help...plz, about to give car away
Old 12-30-2005, 09:07 PM
inatalonIXLR8 inatalonIXLR8 is offline
Re: engine problem
The more information you can throw at us, the easier it is for us to take a guess at it.
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
Old 01-06-2006, 05:30 PM
Re: engine problem
ok i put a water pump and timing belt, spark plugs and wires , and egr valve the car will idle after start up , but will shake bad, and then the engine you die out , and i will have to wait a come of mins. and start it up
Old 01-06-2006, 08:37 PM
Re: engine problem
Did you do the timing belt yourself? Perhaps it's a few degrees off timing. Were the spark plugs gapped properly?
Old 01-08-2006, 04:31 PM
Re: engine problem
how do i find out if the timing is off a little bit, spark plugs yes
Old 01-08-2006, 05:45 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: engine problem
Get a timing light and figure it out that way.
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
