Old 12-30-2005, 06:07 PM
oneheavyhorse oneheavyhorse is offline
lean error obd code 99 trans am
My daughter just phoned me and has an intermittent check engine light. The error codes are P0171 and P0174. These are lean error codes for left and right bank respectively. I don't have the car here yet, but here are my questions.
1) How many O2 sensors are there? does this sound like they are bad?
2) Is it the MAF or MAP?
3) Anything else to check?
It is intermittent and I don't know the circumstances setting the error or clearing it when it goes away. It is a 99 Trans Am, V8. Car runs fine even when the check engine light is on.
Thanks in advance.
Old 12-30-2005, 06:27 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Re: lean error obd code 99 trans am
1. There are 2 O2's on each side. One before the cat and one after per bank.
2. Could be. Most likely the MAF. May need cleaned.
3. Fuel pump.
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 01-03-2006, 01:50 PM
Helmuth48's Avatar
Helmuth48 Helmuth48 is offline
Also check for a vaccum leaks....and yes..trying cleaning the MAF....it works on Fords!!!!
