have trouble with a 1999 voyager
Trouble is, while out today it started bucking while on the trottle so i put a small can of gas line anti-freeze in. Then the speedometer gave out and the transmission seemed to be acting up.. Now I got her home and put her in the garage to have a look and I removed the air box for a better look and now it won't start. Anyone seen this before?
Re: have trouble with a 1999 voyager
I heard there was a recall on something like that. I would check with the dealer on that one. I think it has to do with a vac line, but check with the dealer.
I'm not sure about that but now she does not have any fire.
I'm noticing things all the time. Is the auto shutdown relay suppose to be clicking while I'm cranking it over.. Remember I have no spark and it won't start.
Yes, it does click while cranking. You probably have a bad cam sensor, or a bad crank sensor or a faulty PCM. Either one of these could be a cause for no spark. As far as no speedo and tranny problems it would be your speed sensor. I'm not sure if you can do the key method to retreive engine codes on this particular year model.
On the 1996 and newer, he should be able to because it has an obd2 ecu.
Yes the key method worked today but all I get is code 55 which means there are no codes..I may have erased them when I removed the battery terminal for the night in the garage..
Check the coil. Go to Allpar.com for more info on chrysler transmissions and other maintence issues.
