Old 12-30-2005, 05:24 PM
DRTaurus DRTaurus is offline
Angry 99 Engine surges only with A/C & heater on
My 1999 Taurus engine idle speed increases about 100 rpm for a second then drops back to a normal idle for about 5 seconds. This happens only when the A/C or heater is on, not with the vent. If you don't have your foot firmly on the brake the car will budge ahead. It's fine travelling at speed.
Old 12-30-2005, 06:26 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 96 Engine surges only with heater on
Check the idle speed control motor. When the A/C is on, the rpm's should increase approximately 100 and stay there while the compressor is on. Also check to see how often the A/C clutch cycles. If it is the same as the engine surge, check for proper refrigerant level in A/C system
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 01-08-2006, 09:01 PM
You got it way2old. Thanks
