Old 12-30-2005, 04:54 PM
Zufan Zufan is offline
Please advice on how to replace FUEL FILTER for Civic 90
Hi guys
Could anyone please advice on how i change the fuel filter on my 1990 civic ?
I read that you need to first unbolt the banjo bolts but i have no idea which ones these are. Does anyone know if there are any online photographs showing you how to do this ?
the problem is i dont know which bolt is which so i would need a better description of it so i can identify which bolt is which.
any help is immensley appreciated.
Cheers
Katrina
Old 12-30-2005, 05:17 PM
Terry28 Terry28 is offline
Re: Please advice on how to replace FUEL FILTER for Civic 90
Originally Posted by Zufan
Hi guys
Cheers
Katrina
http://www.marklamond.co.uk/howto/en...uel-filter.htm
To change the fuel filter!
release the fuel pressure before changing the fuel filter
Old 12-30-2005, 05:58 PM
Re: Re: Please advice on how to replace FUEL FILTER for Civic 90
Sorry Terry.. just one more question.
I looked at the images and under the very first image there is this " First of all remove the intake tubing from the throttle body and filter box " . I dont know where exactly this is as the image does not have arrows saying which exact part it refers to..can you help ?
thanks heaps.
Old 12-31-2005, 02:41 AM
Re: Re: Re: Please advice on how to replace FUEL FILTER for Civic 90
thanks heaps.
This is the airbox
Here is the pic of intake tube from the throttle body to the airbox (Inside the yellow)
They should be easy to remove, just remove those pipe that goes to the intake box.
Ps. U might want to change your air filter while you're at it, if its dirty. K&N is pretty good.
Old 12-31-2005, 05:52 AM
Re: Re: Re: Re: Please advice on how to replace FUEL FILTER for Civic 90
Wow!!
thanks for taking the time to illustrate it .
i feel confident of tackling it now.
Cheers
Katrina
This is the airbox
Old 12-31-2005, 01:47 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
word of advice, banjo bolt under the service bolt is a pain in the ass to get off, its round with two flat sides, think a 19mm fits it, but I may be wrong. They make a special tool to take it off with, your local parts store may have it to loan out if you get in a bind and need it.
Old 01-01-2006, 07:35 AM
thanks for the heads up ThesilentChamber.
I will try it with a regular wrench and see what happens...i am in London and i doubt auto parts store would loan me the special wrench over here. Hopefully i wont need it...but if i do, do they just call it "banjo bolt wrench " ?
Thanks again
Katrina
Old 01-01-2006, 03:48 PM
Forunn Daberator
Not sure if it has a real name, its just a tool made for honda fuel filters.
Old 01-02-2006, 02:56 AM
livinincalifornia livinincalifornia is offline
Send a message via AIM to livinincalifornia
I used regular wrenches and had no problem, but I bent the holder a bit. Why do you need to take the intake hose out?!
Old 01-02-2006, 05:55 PM
Livinincalifornia..thanks for responding..i am a local SF gal now living in London .
Thanks you guys..
Well i read online that it was advised to take the intake hoses but when i went back to my car and re-inspected, it does not appear necessary to remove intake hoses to remove filter..
BTW can anyone shed some light on this..i imported my Honda from Austria and it is a CIVIC, 16 Valve , 1.4 (something something dont remember the last two digits ) fuel injected and the model is ED6 . When i was shopping for a new fuel filter the auto shops could not find my model on there database..can anyone please tell me if there is a difference between ED6 AND ED7 (they have parts for ED7 ).
I would really appreciate it..i see honda's that look exactly like mine around town but i dont know what the ED6 actually stands for.
Thanks in advance
Karina
Old 01-03-2006, 04:22 AM
Forunn Daberator
The fuel filter will be the same.
Old 01-03-2006, 07:32 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
A regular wrench will work fine. It is a pain though. I had to get on the driver side of the car to wrench it off. GL
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 01-06-2006, 03:39 PM
Hi..me again-
I took off the fuel filter earlier today...BUT i'm real worried about the tiny hole where the gas comes through..(the tiny hole found inside the banjo bolt..after taking off the service bolt ) I just discoverd that the whole needs to be aligned perfectly in order that the fuel does not flow out the sides of the bolt...dont know how the heck i am going to align it correctly before i tighten it.
Also, I dont really understand what it means to tighten the banjo bolt to " 16ft./lbs " .
I am very worried i might mess things up...since i have to screw the bolt back..how can i allign the hole in the correct position and screw it on all at the same time ?
Thanks again
K.
Old 01-06-2006, 03:53 PM
What I did was marked the top of the bolt with a light colored marker where the hole was and then I tightened it accordingly. Not too tight. 16ft./lbs. isn't that much...
2010 Honda CR-V EX
Old 01-06-2006, 04:32 PM
Re3:Please advice on how to replace FUEL FILTER for Civic 90
thanks for the prompt response..
Yes i did plan to mark the bolt too but the thing is how do you determine exactly how tight i need to tighten it..do you mean you used nothing else other than just marking the top of bolt where the hole is ? did you get it perfectly alligned the first time out ?
Thanks
K.
It seems that with a tiny hole like that...one would be trying all day long to allign it...
