Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 12-30-2005, 04:36 PM
BrickWall BrickWall is offline
Send a message via AIM to BrickWall
Engine Swap (this ones different!)
I was thinking about buying a cheap, early/mid 90's eclipse or talon to swap in a 4.6L Ford V8.
I don't know much about these cars, so I came to ya'll asking if it will fit. I'm also gonna change out the transmission with the Mustang 5-speed standard.
What do you guys think?
Old 12-30-2005, 09:54 PM
inatalonIXLR8 inatalonIXLR8 is offline
Re: Engine Swap (this ones different!)
Maybe if you made it rear wheel drive. Keep in mind that the weight distribution will be alot hevier in the front, affecting cornering ability. Suspension will of coarse need to be replaced with beefier units. If you're really serious about taking on this type of project, why don't you consider getting an Eclipse GST (front wheel drive) and remove the back seat, and place the V8 in a mid engine configueration to drive the rear wheels. Now that would be a machine!
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
Old 12-30-2005, 11:06 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Why dont you just build a GST/GSX? If the car had a shitty, unpowerful, and virtually unbuildable engine I'd say go for it, but with the 10 grand you'd need to swap all that shit, you could have built one monster GSX.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 12-31-2005, 02:47 AM
duffman868 duffman868 is offline
asking this question prove you dont have the fabbing skills but if i were to drop a v8 in any dsm. i would get a 1.8 and drop in a northstar. i with enough fabbing skills this swap might be possible for about the same as a 4g63t swap would run you but you would have 100 more hp stock but no turbo
1990 Honda Civic std - ls swap
1994 Eagle Talon dl - daily driver and slow as balls
I should make a paper mache turbo and manifold.. I shall call it.. the SSAutoMache
