Old 12-30-2005, 02:30 PM
nytelush nytelush is offline
battery cable
my 96 blazer has a coroded cable head which my dad happened to break off, i need info on replacing either the head or the whole cable.
Old 12-30-2005, 02:56 PM
billibong's Avatar
billibong billibong is offline
Re: battery cable
If the cable is in good shape, just replace the head.
Go to your local parts store - autozone, advanced, o'reillys, pep-boys - and pick up a replacment head and new felt washers - should be <$7.
cut off the damaged end of the battery cable and strip back about 2" of the insulation - use a utilty or pocket knife.
Attach new head to the stripped end of the cable and make sure it is tight and long enough to reach the battery.
Clean the connectors on the battery using baking soda and water and a terminal cleaner or wire brush, rinse with plain water then apply a thin layer of vaseline after you attach the connectors.
The baking soda and water neutralize the corrosion and the vaseline protects it from reoccuring.
Hope this helps.
billibong
99 4X4 Blazer LS Vin W
Repairs:
U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference)
F & R Brakes and Rotors at 110,000.
Infinity Speakers to replace the blown factory sets.
162K+ and still kicking.
Old 12-30-2005, 04:19 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: battery cable
If you want a good long lasting repair replace the hole cable.
Only use the add on end for a emg. repair untill you can get the cable.
Them add on ends are electrical system killers.
They will cause bad connections that will damage charging system or even pcm problems.
They will bit you in the rear sooner or later.
Do it right. Replace the cable.
MT
MT
Old 12-31-2005, 07:55 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Re: battery cable
Try opening this thread. I'm not sure if your 96 is the same as my 2000 but this should help.
http://www.automotiveforums.com/vbul...d.php?t=439471
