Old 12-30-2005, 02:26 PM
Sycope Sycope is offline
Send a message via MSN to Sycope
Angry Need Help/ Advice about airbrush and Compressor
Hi guys I had a really good xmas and got a testers compressor and a revell airbrush. The trouble i have is that the hose fittings are totally different the one on the compressor is massive compaired to the one on the hose for the airbrush.
Anyone got any ideas what i can do can i get a hose with the correct fittments on for each end or is there an adapter that i can use to reduce the size of the fitting on the compressor.
Old 12-30-2005, 02:43 PM
freakmech's Avatar
freakmech freakmech is offline
Send a message via AIM to freakmech
Take them to a hardware store and the guy in the plumbing section will get the right reducer for you.
Friends dont let friends buy die-casts...
"If it can't run 24hrs., it aint sh!t...." -me
Old 12-30-2005, 03:14 PM
Re: Need Help/ Advice about airbrush and Compressor
would do but my girlfriends brother is a plummer and he doesn't know of any fittment in pluming thats that small
Old 12-30-2005, 03:57 PM
Vric's Avatar
Vric Vric is offline
Re: Re: Need Help/ Advice about airbrush and Compressor
Then he need to quit his job
Old 12-30-2005, 04:07 PM
freakmech's Avatar
technical it is probably an air condition fitting or something so he might not know. look i had the same issues with my Iwata airbrush and Paasche compressor. i found the parts at the hardware store.
Old 01-01-2006, 11:57 AM
Dean23's Avatar
Dean23 Dean23 is offline
I just got a compressor yeterday and the hose for my paasche vl srews right on to the compressor outet. Im going to go buy some fitting so I can put a water seperator on. YOu probably just need to go to a plumbing shop and get a bushing to reduce it from 3/4 inch down to 1/4 inchSometimes you might need 2 bushings to get to the size you need depending on the size you are starting out with
get me a hardtop with a decent engine and make sure it's got a big trunk
Dwight from Sin City
Modern cars - they all look like electric shavers
Marv from Sin City
