Go Back   Automotive Forums Car Chat > Cars in General
Old 12-30-2005, 01:51 PM
Bob AZ Bob AZ is offline
Fine grit in clear coat - how to remove?
Posted this also in the exterior section but it maybe more of a detailing question:
Had a shop do a complete re-paint, (red over red) had to move out of state with no time to have them "buff out" trash in the clear coat so now I'm stuck with doing it myself. Paint has had plenty of time to cure now, but I need to know what to use. This is dust/grit actually embedded in the clearcoat, not dirt deposited after the clear coat dried. It is not large but it definitely is rough as you rub your hand over it. This is a Jeep that will next get woodgrain vinyl so I want it to be smooth before I install it. I read about clay but am not sure if it will remove embedded material.
Old 12-30-2005, 05:42 PM
Les7K's Avatar
Les7K Les7K is offline
Re: Fine grit in clear coat - how to remove?
If the paint shop didn't get a chance to "buff" it out then it sounds to me like a clay bar might not work for you.
A clay bar will lift off such things as industrial fallout, paint overspray, disc brake dust, tree sap, acid rain, oxidation and other nasty contaminants that have adhered to your paint's surface.
But if the paint itself is rough, you really need to have it buffed or even color sanded then buffed. Both of which, if your not familiar with, I'd recommend having done by a professional.
Beauty is only skin deep,
but cool goes all the way down to the frame.
-Stuf Products LLC
