Old 12-30-2005, 12:46 PM
space-monkey2 space-monkey2 is offline
Banned
Unhappy Speedometer Gear 420A
My speedo stopped working while i was driving a while back, ive switched the sensors a few times with extras laying around and checked all the wiring. 2 days ago i pulled out the speedo sensor from the tranny, put my finger in the hole where i could feel the gear, and had my friend jack up mycar and throw it in 1st and gt it movin. and the gear is like broken off the shaft its connected to. so the question is.... is it possible to fix without having to take it to a shop? like does the inspection plate let you change the gear or what? throw a line if you know anything. thanks
Old 12-30-2005, 02:33 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Speedometer Gear 420A
It seems like you should take it into a shop. If anything is broken in the tranny, you should take it in right away, and see what they say.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 12-30-2005, 04:10 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
If the gear broke pff, then you will have to replace it. The gear is plastic so just let the gears in the tranny grind it up. Then after a few days, change the fluid in it and it should be alright.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 12-30-2005, 06:43 PM
Banned
Well you can feel the geer in the tranny, the white plastic one. but where it connects is broken... if i could fit super glue in it, lol. but id assume that gear was easily replaceable if its plastic... like there is that inspection plate on the side... so id assume it might slide out. but i just wanted to know if anyone has had this problem...
