Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 12-30-2005, 11:13 AM
yoguy1 yoguy1 is offline
95 dakota oil leak
I have a 4x4 1995 v8 that has a substantial oil leak that appears to be coming from the top of the bell housing near the distributor. It seems to be in the area of the sending unit. Oil travels down the housing next to the transmission filler tube. Before i start tearing things apart i was hoping someone had some helpful info. thanks in advance.
Old 12-31-2005, 10:06 AM
troy1 troy1 is offline
AF -Advisor
Re: 95 dakota oil leak
very possible the sending unit is leaking cheap & easy fix you need a 27MM socket ( i had to get mine machined out) so I recommed getting a oil pressure sending unit socket from a parts store.
