Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 12-30-2005, 09:31 AM
Projectcelicagtx Projectcelicagtx is offline
Radiator Troubleshooting
Hey i have a fan problems i need help diagnosing. My fans will not turn on and its causing my car to run warm. I need to know how to find what the problem is. Iv checked fuses, relay fuses. And iv hooked both the fans up to direct power and niether the ac or radiator fan will turn on? Is there something else to check?
Old 12-30-2005, 12:37 PM
drunkpuppy drunkpuppy is offline
Send a message via MSN to drunkpuppy
Re: Radiator Troubleshooting
have you checked to see that your radiator is full. A couple months ago my water pump went out...which caused me to lose antifreeze...and when the radiator gets so low on antifreeze the fan wont kick on (i would think that it should in a time like that). I didnt realize it for a while though cause i replaced the radiator less than a year ago. Anyways, try that. If its low fill it up, and see if the fans kick on.
Old 12-31-2005, 06:23 PM
Found the problem..... It somehow must have shorted out or lost power for some reason. I started unhooking the power supplies and things and making sure all the wires werent damaged and they all worked so once i plugged everything back up it all the sudden reset itself and started working. haha idk what i did but its working now.
