Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-30-2005, 09:05 AM
rodeo01 rodeo01 is offline
Send a message via MSN to rodeo01 Send a message via Yahoo to rodeo01
Angry Rear Disc Brakes
I have a 2001 Rodeo 4X4 with an automatic tranny, 3.2 V6, ABS. My rear disc brake don't seem to be doing much work. I change them (they weren't worn much) and still have the same problem. I have bleed the rear with no luck.
Old 12-30-2005, 09:10 AM
directory's Avatar
directory directory is offline
Re: Rear Disc Brakes
any codes popping up?
if they weren't worn much, why did you change them? how do you know they aren't working--is stopping an issue now? sorry for all of the questions, just want to get a bigger picture to help find a remedy.
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear
SKYWARN
we be clubbin'
--B
Old 12-30-2005, 09:53 AM
rodeo02 rodeo02 is offline
How do wear patterns on the rotors look? Do the caliper pistons have full stroke? also make sure the pads and calipers are floating freely. The rears by design do less braking than the fronts, it's not 50/50 as far as I know. How do you know that backs aren't working? Rodeo nose dive is common on factory (or worn out) shocks. New shocks = no nose dive.
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 12-30-2005, 09:59 AM
Joel
Old 12-30-2005, 12:27 PM
Re: Re: Rear Disc Brakes
No codes. I changed them cause they where hard. I can tell they are working but not real good. If I hit them twice they work better, that's why I bleed them.
Old 12-30-2005, 12:29 PM
The nose dive is one reason I thought they weren't working right. I replaced the shocks 6 months ago.
Old 12-30-2005, 01:15 PM
If all wear patterns are good, it's possible the rotors or pads are glazed (too smooth). The rotors always looked horrible on my 2002, even when the truck was brand new @ 5mi. The brakes always took a firm foot on ours. I changed the factory front pads with another set of OEM's at 36Kmi, still the same.
Joel
Old 12-30-2005, 01:23 PM
alphalanos alphalanos is offline
How can you feel the rear brakes? I'd say change your front rotors and pads and bleed it. You should notice an improvement then.
96 EJ6. Future home of boosted B18C1.
