Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 12-30-2005, 05:58 AM
plex4r plex4r is offline
Brake lights do not work, dome does
On my '95 EB Explorer the left and right brake lights will not come on, but the dome brake light does work. I have replaced and checked the bulbs and they are fine. The park lights, and other real lights are working fine. All fuses are OK, although I doubt this could have been the problem anyway since the dome brake light is working fine.
I have a basic wiring diagram, but it is only a high-level schematic from my Hanes repair manual. The Left and the Right appear to come from a common point. I am thinking this may be the loose connection.
Can someone point me where these wires originate, or where can I view a more detailed wiring diagram that actually show the location of components in the car?
Any other idea on how to diagnose?
Thanks!
Old 01-25-2006, 09:30 PM
jd-autotech jd-autotech is offline
Re: Brake lights do not work, dome does
take a look for a bad connection at the multi function switch on the column
Old 01-26-2006, 07:45 AM
JD Thx for the advice.
I figured out that the problem is with my Lamp Outage Module that is under the console between the driver and passenger. It was a bad connection because I have bent the pins a little and now the brake lights are all working fine. If it does give me trouble again I'll just replace this $62 part.
