Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 12-30-2005, 01:01 AM
inatalonIXLR8 inatalonIXLR8 is offline
Anyone ever put a torque spliter in the GSX / Tsi AWDs?
The adjustable center torque spliters that come stock in an Sti sure would be nice to play around with in our Eclipses and Talons. Anyone know if this has been done in our cars before? And does anyone know the split ratio that is in these cars already, I'm guessing somewhere around 60 rear / 40 front.
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
Old 12-30-2005, 09:11 PM
Re: Anyone ever put a torque spliter in the GSX / Tsi AWDs?
Anyone have any ideas on this?
Old 12-31-2005, 06:00 AM
shadow eclipse shadow eclipse is offline
Send a message via AIM to shadow eclipse
Im pretty sure its a 50/50 split on our cars. Aleast thats what Kevin says
95 GSX 14.748
90 GSX
Old 01-08-2006, 11:21 AM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
I always thought it was 60 front 40 rear and if you get a spool put in the center dif it puts it at 50/50 but I could be wrong. and I agree with inatalonIXLR8 that a adjustable center torque splitter would rock
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 01-08-2006, 07:12 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
wrong, its only a 50/50 split of you have the center diff welded...
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 01-08-2006, 07:33 PM
blk_srt's Avatar
Re: Re: Anyone ever put a torque spliter in the GSX / Tsi AWDs?
or get a spool
Mods:
Old 01-08-2006, 09:21 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
since we have a viscous its not a set split until it locks. once it locks its 50/50. a welded center diff or a spool will also make it 50/50
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 01-08-2006, 09:41 PM
kjewer1 kjewer1 is offline
AF - Advisor
This is correct, and this is my usual response as well. Think twice before calling "wrong" with such imagined authority
Its an open diff until there is enough slippage in the VC to heat the fluid enough to lock it. Once it is locked, it is a 50/50 split, unless there is a serious difference in traction and enough force to make the VC slip (towing by two wheels comes to mind).
A spool and similar devices will lock it at 50/50, so most people call it a 4wd instead of AWD at that point...
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 01-09-2006, 07:40 AM
Anyone ever hear of an aftermarket adjustable unit that you can switch between settings on the fly?
