Old 12-30-2005, 12:51 AM
Steermaster Steermaster is offline
Send a message via AIM to Steermaster Send a message via Yahoo to Steermaster
HELP w/ 92 Stealth Transmission
I have a 92 Stealth that recently had the transmission go out on. It was just a regualar automatic tranmission with a SOHC engine.
I have a 2nd stealth with the same engine but has a 5 speed manual transmission. The only thing is the engine is blown on that one.
Would it be possible to swap the transmissions from one to the other. I have heard that i will have all sorts of electrical problems with the computer but i wasn't sure. Also if that is the case would i be able to swap the computers out as well to solve that problem.
OR would it just be easier to swap engines (and would it work easier).
PLEASE help me...i need my car working again lol
Old 12-30-2005, 07:01 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: HELP w/ 92 Stealth Transmission
Computers are no different between Auto and Manual. You will have to splice into a few wires to 1) Let the car start and 2) Make your back ups work. Also you need pedal assemblies, starter, flywheel, and probably some other stuff I forgot. Also if its a 93 the tranny is coming from then you need to swap out the axles too. I beleive there is a write up in the FAQ.
Old 12-30-2005, 09:11 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
for that matter, why not just switch the engines... Idk, it seems more reasonable to me, b/c u're gonna have to put in the master cylinder (cut fenderwell and all that bs)... and all the linkage, and it seems like more hassle to do that then switch the engines...
I've never switched out an engine... but I've pulled a tranny... it seems like a helluva lotta work to do the conversion... but that's up to you my friend.... good luck and keep us posted
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 12-31-2005, 11:14 AM
well....
well i plan to go pick my car up from the mechanic today. I think i will jsut pull the entire engine. I din't think about having to cut the firewall and al that for the linkage.I will kepp you posted on how its all going....hopefully not to long until its going again
