97 V6 Rough Idle and Questions
I have a 97 V6 automatic that I have a few questions about. My truck seems to idle rough when it is in gear , either forward or reverse, but it is ok in park or neutral. I have cleaned the throttle body and the air filter is a new K&N filter, but the engine still seems to idle a little rough. Any suggestions.
I have read in a couple of forums and posts about resetting the PCM by unplugging the 3 plugs for 10-15 minutes to reset the learned parameters, but I haven't done this as of yet. Any suggestion about this? I also noticed that the truck seems to take quite a while to warm up and I have noticed that the radiater fan is always turning no matter what, is this normal or could the fan clutch be bad? I have searched and read all sorts of posts and I am just trying to get some info on what might work best. Anyone ever hear of a mod where to you remove the original airbox snout/trunk and make the hole bigger to allow for more air to flow to the filter box? I have read that this can help to increase gas mileage but may reduce HP a bit on the downside? Any thoughts? Thx for any help and suggestions. |
Re: 97 V6 Rough Idle and Questions
Re: Re: 97 V6 Rough Idle and Questions
Yes I have checked the codes and all that I seem to get is 55.
Thx, fastlife Quote:
The fan has a viscous clutch and will turn with the engine... should not free-wheel with the engine off and turned by hand. As far as the rough idle, you might try some of the easy stuff first like cleaning the injectors.
