Go Back   Automotive Forums Car Chat > Kia > Spectra | Cerato | Forte | Mentor
Spectra | Cerato | Forte | Mentor Couple 4 and 5 door models.
Old 12-29-2005, 06:43 PM
monsequoia monsequoia is offline
High RPM issues
I have 2001 kia spectra, manual. My car runs constantly at 2000 RPM at speeds 40-60 Mph and 2500+ over 60 Mph. Everything seems to be OK and the car idles fine around 600-700 RPM. What could be wrong? Any ideas.
Old 01-01-2006, 12:03 AM
nick bamberger nick bamberger is offline
Re: High RPM issues
If everything seems to be ok, what makes you think anything is wrong??
I dont know the speed/RPM, but it sounds fine to me. If you think it has changed, you can check for a sticking brake.
The engine is high revving, as well as low power, so you can expect it to revv high at cruising speeds.
Old 01-07-2006, 10:27 PM
cbeck cbeck is offline
Re: High RPM issues
on my 2000 manual trans., the gear ratio/fuel economy is sacrificed for power. it runs around 3000 rpm at 60mph as it was designed to do... while alarming if you're used to driving other makes, this just seems to be the kia way... I still wonder if the cars are just designed for 80kph speed limits?
I'm not a mechanic, I'm the guy people bring their car too when they don't run. I usually scratch my head and tap on stuff, then call the dealer to see if they can help me find the carburetor.
Old 11-26-2010, 08:12 PM
mm6diaz mm6diaz is offline
Re: High RPM issues
I have a kia spectra 2005 and it has the OBD codes 0030 and 2243, the first said heater ckt and the other low voltage heater ckt. please somebody tell me what is happening there. thank you.
