Re: brakes 2000 contour SE
It's usually recommended that you open the bleeder screws to compress the calipers on a car with ABS rather than forcing the fluid back into the system. This isn't so much to avoid getting air into the system, but rather to prevent forcing the fluid back through the ABS pump. I've never really heard of anyone having problems by compressing the calipers without opening the bleeder screws, but for future reference, I'd avoid the practice.
I'd suggest you attempt to bleed the brake lines in the recommended bleed sequence. Your service manual should have the recommended bleed sequence.
As an option, I have been very impressed with Speed Bleeders. They are bleeder screws that replace the OEM bleeders and contain a one-way valve. To bleed your brakes, you simply open one bleeder at a time about half a turn, then slowly pump the brake pedal. The one way valve prevents air from entering the system. They also make compressing calipers very easy.
I don't have any stake in Speed Bleeders, I used them on my track car. I'd drive to the track, then swap tires, brake pads, and rotors once at the track, and would flush the brake system every couple of months. Speed Bleeders almost make the process enjoyable.
-Rod
