Anyone know the difficulty level to replace a bumper, tail light for someone who knows nothing about cars. Is there any guides out there on the net for dummys like me that will dumb it down enough for me to understand.
One more thing, does anyone know the reliability of car parts on ebay such as tail lights. Btw: Some did a hit in run on my car this is why i need to replace. |
Re: Replacing Tail lights bumper
the taillights are real easy. in the trunk, you will see a panel that you can pop off right behind the taillight. this will give you access to the nuts on the back of the taillight. i believe they are 10mm. if you can, do the taillights while you have the rear bumper off. alot of guys have dropped the nuts down into the bumper since the hand space is very cramped. with the bumper off, the nuts will fall too the ground and you can pick them up.
Cool, i checked out the trunk and took the panel off.
Right now I only see 1 bolt, do i have to remove all the plastic in the trunk to get to the rest. Thanks, again |
i went ahead and took everything out, because i'm prone to drop things, all the plastic pieces in teh back aren't hard to take out at all, just keep searching around the edges and make sure you remember exactly how they go back in!
Also there are 3 bolts holding the tailight on as well as harnesses one bolt is close to the opening, another is a mid-way and the last is right next to the edge of the car. its not hard, but its a but pain if you don't have small or nimble hands
![]() Don't act like you don't love it.
503/2000 |
the other two bolts are pretty hard to get to...thats why alot of people drop the nuts. if you have big hands, forget about it. you will scratch your hands up on the plastic. i didn't remove all of the plastic when i replaced my taillights but i did scratch up the top side of my hands.
I just went ahead and took out all the plastic in trunk. I was going to leave it out anyway because of the stereo that I put in the car should I figured hat it was the easiest route for me.
2006 Mitsubishi Eclipse GT Debagged, 18" MKW Rims, 5% Tint, Ralliart Eyelids, Outlaw Racing IM and TB Spacers, Ingals "Stiffy", Energy Suspension Polyurethane Motor Mounts, Tanabe Lower Tie/Strut Bars, Progress Rear/Eibach Front Sway Bar, D2 Racing Lowering Springs, RRE Headers and Axelback, AEM CAI w/ Bypass, 12000k HID Heads, 3000k HID Fogs, Sunroof Wind Visor, Drilled/Slotted Front/Rear Rotors, and Ceramic Brake Pads. |
Re: Re: Replacing Tail lights bumper
2000 Fed. Spec GT-"Lafawnduh" Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp |
Yeh a problem im gonna have is i have a subwoofer box in my small mitsubishi trunk, im going to have to unhook that to be able to get to the plastic.
Thanks for the help so far guys, anyone have any tips about the bumper? |
Yeah...from what I have heard, other cars can do a good job of getting those off...so, if you see any....brush up against one and it might fall off. JK. I havent tried to take mine off so i wouldnt know.
you don't NEED to do the bumper... just be careful and have a spare car in case you need to run to napa for bolts you lose, to be honest, i'm the most accident prone person ever and i didn't lose a nut doing this, make sure you have a hand underneath where your getting it off of and don't move it b/c as soon as you do, you will drop it... it happens...
503/2000 |
Yea basically i got in accident and they wont inspect my car becuase the bumper is smashed into my tail light.
I got another question, will a 2001 gt eclipse bumper fit on a 2000 eclipse GS |
It should...i think body wise all the models are the same....especially for the first 2 years.
Re: Re: Re: Replacing Tail lights bumper
503/2000 |
