fuel pump
I was wondering if a 89 suburban should have an electric fuel pump? I know that there is not a mechanical one attached to the front engine block but when I turn the key on I dont hear the pump cycle. The truck starts fine every time. Just wondering about this. Brian
Re: fuel pump
If you have TBI, you have an electric fuel pump inside the gas tank, so you can't hear it!
Mine went out at 150,000 miles, about a $300 job to drain and remove tank, change pump, reinstall and replace fuel. Now at 386,000, still running fine, fingers crossed! |
Re: Re: fuel pump
Re: fuel pump
Could be a lot of things, Brian. For example, I've seen intake manifolds clogged with deposits choke off an engine similarly.
Should be easy to check the gas gauge. You don't mention what year Sub you have, but the tank should be somewhere between 31 and 42 gallons. Because of the shape and mounting angle of my Sub's 37 gallon tank, when the gauge indicates the first half of a topped off tank (full down to 1/2) is used, it's actually burned at least 20 gallons. The second half (1/2 down to empty) is about 15. If it suddenly took 34 gallons to top off from a gauge reading of 1/4 I'd figure I have a sending unit problem. I change my fuel filter annually, about 30,000 miles, and at that point I cannot blow through the used one; the pump can, but it's definitely working harder. If yours has never been changed in 122,000 (it happens), I'd be surprised if the truck runs at all. Changing the filter yourself is cheap, quick and easy so I'd recommend you go ahead and see if it helps. A good independent garage will check out your OBD I and confirm the problem "hands on" for about $60. That's more than the cost of an OBD I scanning tool if you're a do-it-yourselfer. And Midas Muffler shops frequently do free "Cbeck Engine" light diagnosis for FREE, I recently took advantage of that on one of my BMWs. They might have a similarly good deal for your OBD. Good luck and Happy New Year! |
Re: Re: fuel pump
Thanks, I picked up a fuel filter last night and will replace it this weekend. It should give me something to do while I wear off my hangover I anticipate coming. My suburban is a 89. I cant remember if I posted that I had ran the tank low. It was at a quarter or lower. And the truck stalled on me from a stop and incline. I filled the tank to half that night and drove home with some of the hesitation still there. Im hoping that I did indeed clog the filter and nothing more but I still cant figure out why it would stumble more when the engine is warm though. Have a happy new year and thanks again. Brian
