Go Back   Automotive Forums Car Chat > Ford > Aerostar
Old 12-28-2005, 11:41 PM
Clint M Clint M is offline
Heater motor quit running
This problem started last year. As I was driving the heater motor quit running but after a while it would run again. Today Dec 28th it quit again and hasn't started. I don't know what is causing this but I am going to check the fuses and also see if there is a breaker that might be weak. If anyone has any sugestions please reply to this message. Thanks.
Old 12-29-2005, 10:38 AM
IbenTruitt IbenTruitt is offline
I think you'll find the brushes in the blower motor have worn out. The commutator that the brushes ride on is probably to worn to take another set of brushes if you could find a set. You'll have to replace it. They're easy to get at so it isn't a very hard job.
Let us know where you find a replacement.
Old 12-31-2005, 03:51 PM
Bill_Qol Bill_Qol is offline
Re: Heater motor quit running
I had the same problem. I was checking the circuit and fiddled with the wiring and it started working. Hasn't quit since. so ?????
Old 01-13-2006, 10:00 PM
pennypicher pennypicher is offline
Send a message via Yahoo to pennypicher
Same thing on my 96 but I had to replace it. Fiddled with the brushes too many times. Was down to the wire. NAPPA was about $55.
