Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-28-2005, 11:05 PM
Ramblin Fever Ramblin Fever is offline
EGR code, could it mean bad IMG
instead?
The code is P0401 stating EGR flow insufficient, but I've heard other's saying the rough idling symptoms could also be a bad/leaking intake manifold gasket.
Is it possible the code is not related toward the EGR, or are the codes pretty honest?
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 12-29-2005, 09:47 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: EGR code, could it mean bad IMG
Nope I think you are correct. That is a possiblity too.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 12-29-2005, 11:38 AM
rodeo02 rodeo02 is offline
If you are getting an EGR code, it is EGR system related. If you had a vacuum leak massive enough to prevent EGR flow, your 3.2L would run horrible, if at all.
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 12-29-2005, 07:48 PM
Cool ok, thanks.
No it's definitely running fine, idle is steady at 750 rpm just a tad rough though.
I'll re-clean the EGR and check all the connections and go from there.
Thanks!
1997 3.2L V6 Rodeo
Old 01-07-2006, 06:09 PM
96IsuzuRodeo 96IsuzuRodeo is offline
I had the same exact trouble code/problem with my 1996 Rodeo (118K miles). The EGR opening at the intake plentum was almost completely closed with carbon buildup.
To fix this problem, you have to unbolt the EGR valve and small aluminum adapter from the intake plentum, and scrape all of the carbon buildup from the EGR opening in the intake plentum and adapter.
When you are ready to do this, have someone turn on a canister vac and hold it near the EGR opening of the intake plentum while you scrape the carbon buildup. This way none of the carbon will fall into the intake. Finally, re-attach the EGR valve and adapter with new gaskets, and you are done.
Oh, don't forget to erase the trouble codes by disconnecting the battery for a few minutes. Good luck.
Last edited by 96IsuzuRodeo; 01-09-2006 at 04:22 AM. Reason: added additional details
