Old 12-28-2005, 09:46 PM
fordtaurusowner11 fordtaurusowner11 is offline
Keyless Remote Programming
I have a keyless entry remote and I wanted to know if anyone knows how to program it for a 1999 Ford Taurus. It already had one remote so it's set up for it, any help?
Old 12-29-2005, 03:01 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Keyless Remote Programming
If you have the owner's manual for your car, the instructions are in there. If not, do a search in this forum. It's been posted before, so I'm not going to re-type it all.
-Rod
Old 12-30-2005, 09:53 AM
fragmore fragmore is offline
Try this. Sit in the car. Turn the key from off to on, without starting, until the locks cycle up on and off. Immediately push one of the buttons on the remote , the locks should then cycle. You are done. You will need to turn the key from 5 to 10 times depending on your car.
All of this is spelled out in the owner's manual, which is available as a pdf file on the net, do a search.
Old 12-30-2005, 09:58 AM
Replacing lost transmitters
Take all your vehicle’s
transmitters to your
dealer for
reprogramming if:
² a transmitter is lost
or
² you want to
purchase additional
transmitters (up to four may be programmed).
To reprogram the transmitters, place the key in the
ignition and turn from OFF to ON five times in rapid
succession (within 10 seconds). After doors
lock/unlock, press any control on all transmitters (up
to four). When completed, turn the ignition to OFF.
The doors will lock/unlock one last time to confirm
completion of program mode.
All transmitters must be programmed at the same
time.
