Old 12-28-2005, 08:44 PM
Escort_LX Escort_LX is offline
Question PCM or SRS (AIRBAG) MODULE?
Hi all,
I will not pressure but I’m in a hurry for replies as to what this little blue box is.
The hurry comes as today going out to work I stopped at the mail box, then when I got back to my car thick smoke was coming from under the instrument panel, I removed all and to my surprise this blue thing had a burn mark and a burn smell. Later after taking pictures I tried to remove the plugs and they are a bit wet.
I knew before that I needed to replace my heater core so I know were the wet comes from.
The Hurry now is this blue thing. By the way, risking fire the car runs fine and the AIRBAG WARNING LIGHT was blinking when this happened.
Below are the pictures.
If ain't broke dont fix it.
Old 12-28-2005, 09:19 PM
dougand3 dougand3 is offline
Reading in the Haynes, this MAY be the electronic diagnostic monitor for the SRS. It supplies current to the airbag if battery power is cut off in a collision. It also checks the system on every startup causing the airbag light to go on, then off (if SRS working properly). It says run to the dealer. Would I? Dunno - it also shows how to disconnect/pull the steering wheel and passenger airbag modules.
Old 12-28-2005, 11:34 PM
AltecZX2 AltecZX2 is offline
Send a message via MSN to AltecZX2
Re: PCM or SRS (AIRBAG) MODULE?
thats not a pcm
FORMERLY: zx2srdotnet(1,380 posts)
2001 Esxort ZX2 - Traded
2000 Escort ZX2 S/R - Sold
2003 Mustang Mach1 - Totaled
2014 Altima 2.5 S - Purchasing Soon
Old 12-28-2005, 11:51 PM
So, I can disconnect that thing from the system and drive safely to my dealer for them to fix that piece of hardware?
Also found an escort airbag control module recall for this, I think I took action too late. But at least I prevented the fire.
http://www-odi.nhtsa.dot.gov/cars/pr...callsearch.cfm
Thanks for saying that it is not the PCM Those are more than good news.
