| Off-Topic Talk about anything other than cars. |
When I hit full boost(about 14psi for now) after a few seconds its like I'm getting fuel cut or something cause the car just jerks and kind of acts like I have a boost leak. I just changed my plugs with some NGK BE7RES gapped at .028 like chunkymilk instructed and that didnt solve anything. Any ideas as to what might be the problem?
2004 Flame Red SRT-4 |Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd| Mods: ![]() |
Re: fuel cut possibly??
I'm having the exact same problem.
1991 GSX 2.3 Stroker |
Re: Re: fuel cut possibly??
That sounds strange but probably not fuel cut because I remember my eclipse with the evo III and no fuels mods topped out at 16psi with no problem. From what I've heard about fuel cut, it's like you just hit a wall while boosting. Have you changed your plug wires also? If you did have a boost leak the car would definitely jerk a lot, I would check again for cracks and holes in your piping.
![]() 05 Srt4 Agp 3147 w/supporting mods ![]() 97 Mx-5 T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box, |
I know I don't have a boost leak I'm almost 100% sure. I just can't figure out what it is.
I just changed the plugs and wires and I've smoke tested my entire intake/exhaust system granted its not pressure testing but all my couplers were just replaced with silocone so those are good. I can't think of anything that could cause this
EDIT: Also if you where to have a boost leak wouldn't it be noticable more than just at full boost, or could it just be a leak that only leaks at full boost? I think I might have just answered my own question
I've had a boost leak before, and when I would try to boost I could hear the turbo spinning but I wasn't getting any boost. hence boost leak. I mean that was a major one but on a smaller scale I think it would be you wouldn't be getting as much boost as normal. I'm getting good boost until 14-15psi, as soon as it hits that the car just fucking jerks like it's stuttering or something. Just like yours It makes me think fuel cut.
Re: Re: Re: fuel cut possibly??
you sure your car isn't cold?
Yea my car seems to jerk like that only when the engine is cold. Than again, it doesnt do it at full boost, just basically in between 1 psi and 13psi(full boost) when its cold. Im really curious about your problem though. Kevin's knowledge would def be appreciated for this.
--the Cruiser-->97 Spyder GST 5sp ---3 inch exhaust, boost/vac gauge, mbc, greddy turbo timer, greddy fmic, greddy type S BOV, 17in wheels --the DD-->99 ACURA 3.2 TL --Sold 92TSi AWD, 6-bolt, auto, evo 3 gt turbo with supporting mods |
My car acts the same way. Only under full boost after about three seconds. Drives me mad! I've always thought fuel cut, but I want to fix it asap.
95 Talon Tsi AWD 5spd 2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
Fuel cut won't act like a stuttering, as someone mentioned. It just straight shuts the fuel off, for a couple seconds. Of all the boost leaks I've had, none really caused a stuttering effect, while 99% of the time this is ignition related. So I would stick with ignition for now. The plugs sound good. I know you said you changed the wires, but there are only two wires that I trust. Stock (ran them deep into the 11s
) and NGKs. I've seen just about every other type fail on install, right out of the box, especially if they are not designed specifically for a turbo car. NT wires don't have to do 10% as a good a job as turbo motors wires do. The compressed fuel air mixture is much denser than what you find in an NT motor, it can be tougher to get a spark through. If the path of least resistance becomes out the side of the weak ass jacket or boot, you're all done. Magnecores are technically a trusted brand meant for our motors, but I've had too many of them shit the bed as soon as I install them. If the description was a little different I might suspect fuel cut if the temperature where you are is very low. Air density goes up of course, and the mas reports this to the ECU as expected. You will hit the limit at a significantly lower boost than you did in the summer. Hard to say if 14 psi is the magic number, since there are so many variables in different setups. All the talk I go into about changing airflow vs boost applies here as well. If plugs and wires dont do it, I usually try to borrow coil packs and ignitors to go one step further. I always have an extra ECU closeby as well, just in case that would do it. Only then would I move away from ignition related troubleshooting and try other things. A boost leak test certainly is easy to do, and I recomend to do them no less often than you would change your oil anyway, so do that if you havent already anyway, regardless of wether or not we exepct it to be the source of the stuttering.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
Just put on stock wires, and yes its pretty cold here(minnesota, averaging 30 or less during the day)
Yeah, my Talon doesn't exactly hit a "wall" like you said with fuel cut. It stutters. I'll definately check the ignition system, thanks.
