Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 12-28-2005, 07:56 PM
medic300zx's Avatar
medic300zx medic300zx is offline
Highoutput Chips
I had replaced another auto with H.O. Chip that inproved gas mileage by 5 mpg and low end torgue great. Had no change on top-end. Has anyone placed an highoutput chip in the computer port of z31 and what kind of changes did they recieve. Thanks to all.
Old 12-28-2005, 08:53 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
Re: Highoutput Chips
what do you mean by high output chip? something that fools the ecu into reading false info? personally i wouldn't mess with the ecu unless i know for a fact it's an approved reflash or solid AFC... which is still somewhat of a kludge method imo....
but hey like i said, i wouldn't mess with it until it needed to keep up with hp mods or new injectors or something...
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 12-28-2005, 09:01 PM
medic300zx's Avatar
The ecu has a chip that can be upgraded on some models to change throtle sensor, so on - They are most of the time known as High Output chips - Was wondering if anyone put one in?
Old 12-28-2005, 09:12 PM
stephenp stephenp is offline
Send a message via AIM to stephenp
the "throttle sensor" only senses idle or floored thats all they can sense allthough it may fool the afm some how......
and they are that way until i belive the z32 model
maybe wrong but i know all single over heads i ever saw for nissans vg series have been that way
Old 12-28-2005, 10:07 PM
medic300zx's Avatar
No I mean it changes the mixture to the throttle body and sensor which changes fuel delivery - That is something the computer can do and cause better mileage as well as more fuel during preformance.
Old 12-29-2005, 07:15 PM
xXxRocker5150's Avatar
xXxRocker5150 xXxRocker5150 is offline
Send a message via AIM to xXxRocker5150
are you sure that it really increases gas mileage by 5 miles per gallon??? that seems really drastic.... do a test and write down your mileage when you have a full tank or half a tank, and than do the same thing when you have like half a tank (if your tank was full) or a 1/4 of a tank or practically no gas left, and tell me the mileage... I'm really interested to see if it works...
Georgey on the subject of midget beastiality pornos
Originally Posted by 1viadrft
I've seen a video or two out of curiousity.... those damn midgets are hung! But then the donkey walks in...
Home Puta's 4Life Crew Member #1
R.I.P Andy, you will be missed by all.
Old 12-29-2005, 08:15 PM
medic300zx's Avatar
No - I did replace a H.O. chip into a 86 Blazer and got 5 miles more to the gallon. You coud hear the change in the idle - I looked into it after that and -TRUE - it changed throttle body mixture and the gave preformance on bottom end - No Top-end change
