Old 12-28-2005, 06:36 PM
loganlott loganlott is offline
Question popping noise in rear end of ss camaro 2000
put new grease in rear end and limited slip additive have no clue what the hell the noise is it has a wobble when you accelerate.
Old 12-28-2005, 06:38 PM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
Did you check your ujoints? Its either that or your rear is living on limited time....
Rusting out Honda Civic $900
Fart cannon muffler: $300
Assorted stickers advertising products you'll never own: $50
Having your @ss handed to you by a brick shaped suv: Priceless.
Yup, I own the suv.
Old 12-28-2005, 06:43 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Re: popping noise in rear end of ss camaro 2000
What grease?
Should have been gear oil. Some good heavy stuff.
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 12-29-2005, 02:06 PM
i put the factory 70w-140 and limited slip additive but like you said the rear end could probably have gone south. but is there anyway there could be slack in the axle due to the fact that it only does it when i turn? because it doesn't make a roaring sound it just feels loose and its like let me say it make a sound like a shock does when the bolts are loose but the shocks are not loose i was just using that to explain the sound. I feel stupid as hell cause i've been around cars all my life. I just restored a 68 ss from the ground up and this just baffles me, maybe i just don't like the sound of buying a new rear end.
Old 12-30-2005, 10:20 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
so wait a second, this problem AFTER you only changed the diff fluid?
Are you sure you accounted for all tools and parts afterward?
Old 12-30-2005, 02:13 PM
RahX RahX is offline
could be the center pin coming loose. those bolts like to break and if it broke at the wrong spot that thing can sling out and catch/catch/catch until it eventually wedges :o. might pop the thing back open and have a look. 70w-140? SAE 75W-90 Synthetic Lubricate GM P/N 12378261 or Equivalent Limited Slip Lubricate Additive GM P/N 1052358 or Equivalent. thats what the factory recommends.
Old 12-31-2005, 03:44 AM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
Re: Re: popping noise in rear end of ss camaro 2000
LOL!!!!
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 12-31-2005, 04:02 AM
bag91's Avatar
bag91 bag91 is offline
Hope you get it fixed
91 RS Camaro V8 305 TBI
cold/ram 14"/3" open element
K/N filter
3.73's
B&M Megashifter
180 thermostat
Flowtech TERMINATOR Exhaust
3" exhaust cutout
Silvania Silverstar Headlights
Ronal R15 Firehawk Wheels
Hankook Ventus Sport (front)
Sumitomo HTR+ (rear)
275/40ZR 17 all around...
_____________________________
Old 12-31-2005, 09:04 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
Re: Re: Re: popping noise in rear end of ss camaro 2000
I left a wrench on the parking brake adjustment nut and started driving and heard it rubbing on the driveshaft. Scared the crap out of me. Someone called me and I forgot all about. So i would definetly say go take a good look.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 01-03-2006, 11:13 AM
wrightz28's Avatar
Didn't say it to be a wise ass or nothing, we've all done it at some point.
Old 01-05-2006, 11:32 AM
Jon2kZ Jon2kZ is offline
My 2000 Z28 has a Torsen posi not the old Auburn style, yours should be the same. Posi additive is not needed with the Torsen.
I used 1.5 bottles of Mobil1 75w-90 gear oil.
*edit* FormulaLT1- DON"T ADVERTISE OTHER AUTOMOTIVE BASED FORUMS ON THIS SITE. Thank you
John
Old 01-10-2006, 05:44 PM
Yea guys i think the guy is right about the pin, i've asked a few other people and they've all said the same thing, so guess what that means i'm gonna be doin tonight. I appreciate it guys yal have been helpful. Oh and no tools left behind, I tend to lay my wrenches on the ground.
