Old 12-28-2005, 05:03 PM
Benjamin2005 Benjamin2005 is offline
Lightbulb stable prt 2
so if ive got 2 subs at 4 ohms each - can i power them with a 2 ohm stable amp??
ALSO
can i power them with a 2 ohm amp (if it doesnt say stable??)
Old 12-28-2005, 06:46 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: stable prt 2
you just need to look at the final impedance
if that's a 2ch amp then you'll be running each channel at 4ohm = not a problem
if that's a mono amp then you'll wire the subs together in parallel to a single 2ohm load and run that on the amp, since it's 2ohm stable that's also not a problem
If there's a power rating at a given impedance, then the amp is stable there. So if you see ####x1 @ 2ohm, then it's at least 2ohm stable.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
