Old 12-28-2005, 02:56 PM
19745mgb 19745mgb is offline
1999 Ford Taurus door lock codes
I purchased a 1999 Taurus with the remote door lock fob. The car has a key pad on the door that allows you to open it if you leave the keys in it etc. I know the manufactorers code is hidden somewhere in the car and this allows you to program in your own code. Anyone know where that original code is hidden? I know sometimes it is on a sticker in a discreet place in the trunk.
Old 12-28-2005, 05:49 PM
TaurusKing TaurusKing is offline
Re: 1999 Ford Taurus door lock codes
Look up under the dash on either side of the steering column, not sure which side, the rap module is up there, I think small gray unit???, should be a sticker attached to it which has the code on it,, if that sticker is not there, it may be on the pcm unit behind the glovebox,,, if all that fails the dealer can pull the code out of the pcm itself for a charge, probably 75-100 dollars, involves hooking up to diagnostics, post back if you find it.. I've looked thru my repair disc trying to find how to pull it out myself, to no avail, it may be in there though,
Old 12-29-2005, 10:48 AM
Re: Re: 1999 Ford Taurus door lock codes
Thanks Taurusking, I will check this weekend and let you know.
Old 01-04-2006, 11:08 PM
SHOcruzr SHOcruzr is offline
Smile Re: 1999 Ford Taurus door lock codes
Above your gas pedal. The sticker usually is facing to the passenger side. You're out of luck if there's another sticker covering the numbers. Usually it is a 5 digit code and the dealer will only take about 10 seconds to find it out for you using their computer. Easiest 1 hour labor charge they'll ever make.
You won't find it anywhere except on that module. If you own a 1995 or older Taurus, yeah you would find it on the trunk under the carpet or something.
