Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 12-28-2005, 02:31 PM
dtmplus4 dtmplus4 is offline
1998 jeep backup lights
My backup lights will not go on and the bulbs are fine, is there a fuse and if so where is it?
Old 02-06-2006, 10:02 PM
grayzor69 grayzor69 is offline
Re: 1998 jeep backup lights
I have the same problem. Has anyone provided a sollution?
Old 02-07-2006, 06:43 AM
BenBB BenBB is offline
If there is a fuse, check diagram on the box cover or read in the owners manuel. If its burt then replace it. The box on my jeep is on the passenger side floor.
Old 02-07-2006, 11:14 AM
GregA's Avatar
GregA GregA is offline
Aren't the backup lights controlled through the Neutral Safety Switch (NSS)? I believe this is mounted on the transmission.
Take Care,
Greg A.
2001 Chevy Venture w/some "enhancements" ~ 105K Miles (Dec. 2010)
1992 Jeep Cherokee Laredo, 4.0L, Automatic ~ 155K Miles (Dec 2010)
Old 02-07-2006, 09:44 PM
bringselpup's Avatar
bringselpup bringselpup is offline
That was my thought too. Not a cheap fix for my 93 but I believe as I was checking prices it looked like a much less expensive part for later years.
93 ZJ White 4.0L PowerTech I6 with +215K miles - Brembo up front Yakima on top Red Top under the hood
Old 02-08-2006, 06:56 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Prolly a dirty NSS, Pull it out and clean ti up or replace it.
Old 02-18-2006, 11:21 AM
1964AVANTI 1964AVANTI is offline
The problem is the NSS. Jeep dealer sells them for $22. I have replaced 2 them - at 35k miles and 75k miles. You will need a 1 inch deep socket. Take care releasing the electical connector - use a small screwdriver to push the tang down. A small amount of trans fluid will flow from the mounting hole.
Old 03-02-2006, 09:12 PM
glass glass is offline
had a persistant trans leak after having it rebuilt , turned out to be the paper thin seal on the NSS, the old one was torn from being reinstalled , new one fixed the problem.....also , had a recall ... dealer installd the step on brake to shift the trans thingy...since then the backup lights dont come on unless the "stick" is jiggled..would take it back , but the dealers service here is not worth the trouble ...best I ever found was in colorado
Old 03-03-2006, 06:53 AM
Was it the "secondary detant system" that the dealership installed?
I had the same thing performed last summer and afterwards it wouldn't go all the way in park, and they said that the cable needed adjusted and wanted me to pay an extra $72 for them to adjust it, I said forget it I would adjust it myself, you would think the adjustment would be part of the service, since it was there fault it needed the adjustment anyways.
So what I did was took the center consol out and loosened up the bolts that hold the secondary detant in place and moved it forward to allow the shifter to go forward enough to allow the tranny to go in PARK. That took care of the problem the secondary detant system also tightened up my shifter alot.
