Old 12-28-2005, 01:47 PM
Benjamin2005 Benjamin2005 is offline
Question stable?
what does it mean when it says like 2 ohm stable? whats with the stable? this is on an amp by the way
im lookin for an amp thats either 150w rms 2 channel 2 ohms or monoblock 300w rms 4 ohms
Old 12-28-2005, 03:13 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: stable?
The lower the impedance of the speaker you attach to the amp, the more current is drawn from the amp for a given output voltage. The amp can only handle so much current though, if you try to draw more than it can handle you'll start to blow transistors. Therefore, amps are given a minimum "stable" impedance, below which the chance of frying the amp due to excessive current draw is too great. In other words, you should be able to attach a speaker setup at or above this rated impedance and the amp won't fuss at you. If you attach a speaker setup below this rated impedance the amp will go into protection and shut off if you're lucky, or blow up if you're unlucky.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
