Go Back   Automotive Forums Car Chat > Chrysler > LHS
Old 12-28-2005, 07:49 AM
thesaxes thesaxes is offline
Send a message via AIM to thesaxes
Unhappy 1999 LHS Radio-no reception
my 1999 LHS radio picks up 2 local FM stations only. I replaced the module ($86) and that did not fix the problem. Any help is truly appreciated!!!
Jerry
Old 12-28-2005, 11:52 AM
repairman2003 repairman2003 is offline
Re: 1999 LHS Radio-no reception
I had that problem when I first got my car. I bought an aftermarket CD player and it solved that problem. I remember doing research on the radios for the LHS and a lot of them had that same problem. You can check the antenna connection, which if you have one that's embedded into your rear window then the antenna box is under the trim that goes behind the rear right door, right next to the rear window. If you disconnect the wire that goes into that box and you still get those FM radio stations then there may be a problem with your antenna. If the stations go out when you unplug the antenna then your replacement radio is junk too. $100 CD player and $10 mounting kit fixed it for me. Good luck.
