Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 12-28-2005, 06:31 AM
undertai undertai is offline
changing fuel filter
After reading mutilple post of stumbling and hesitation I will try and replace my fuel filter. But have a couple of questions?
'93 k1500
How do I go about replacing it?
Where is the fuel filter located?
Any specail tools needed?
Thanks
Old 12-28-2005, 08:35 AM
Old Dave Old Dave is offline
On my 1997 it's located along the frame rail just about under the drivers seat. It has a steel line on the input and output and two standard wrenches is required to remove it. I think there is has a clamp that goes around the filter that holds it to the frame.
1970 GMC 2WD shortbed fleetside
1984 Olds Delta 88 (won't die)
1997 GMC Suburban K1500 W/5.7L Vortec
2000 Dodge Ram 1500 4WD Shortbed Ext. cab
1998 Chevy K2500 W/5.7L Vortec
2002 Harley Custom Chopper
Wife is a late 1951
Old 12-28-2005, 01:10 PM
Dirtsled Dirtsled is offline
Re: changing fuel filter
Easy as that! You will have some fuel leak out when you loosen the fittings so use the normal precaution's necessary. No need to bleed or vent off the fuel line though, I just kept a rag handy to soak most of it up before it splashed into my eye.
Old 12-28-2005, 03:27 PM
wafrederick wafrederick is offline
Banned
You need a 13/16 wrench, a 5/8'' flare nut wrench(Not a cheap one) for the line.You may have trouble getting the fittings loose,they get rusted up and will not come out easily.
Old 12-28-2005, 05:22 PM
777stickman 777stickman is offline
Just did my '98 yesterday. The fittings on the filter and lines are metric, but the 13/16 will work (loose) and 5/8 will work (tight). The clamp on mine also holds 2 lines against the frame. 2 bolts, top & bottom, to take out. Just forward of the filter is another clamp with one bolt. You'll need to take that clamp loose to be able to move the forward line out of the way of the filter. Then slide the filter out of the clamp towards the front. The in & out lines have o-rings on them, so be careful. There will be fuel leaking when the lines are parted.
Old 01-01-2006, 08:09 PM
Rodeo Ron Rodeo Ron is offline
Consider using an anti-seize compound on the threads so next time you dont have to fight the rust. it makes it a whole lot easier next time.
