Go Back   Automotive Forums Car Chat > Nissan > General Discussion
Old 12-28-2005, 01:22 AM
consumerwil consumerwil is offline
9004 Headlight Bulb Wiring
Anyone know what the 3 wires that connect to the 9004 bulb represent (ie. Positive/Negative and Main headlight/Daytime Running lights?) The plug to the 9004 in my Axxess is pyramid shaped so 1 high, 2 below. I suspect there is a short in the original wiring harness and I'll need to wire it direct from my fuse box to the headlight plug.
Thanks in advance..
Old 03-10-2006, 04:27 AM
the3rdlegend the3rdlegend is offline
Re: 9004 Headlight Bulb Wiring
I just got a 9004 today to put in this homemade spotlight deal, I found this looking for the wiring for it. I see your post is a few months old so you probably already figured it out, but if not, here it is anyways. After looking around I found a picture of a wiring harness for the 9004 with a black wire and two reds, so here's he polarities: when your looking into the bottom of the headlight, have the flat part facing down, the tab on the left is the negative. The other two are positive, but I'm not sure which one is which as far as running n' stuff. You'll have to figure that out when you wire it, I'm gonna try runnin both tabs from one wire so I don't really have to worry about that. Good luck.
