| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
no spark?
ok so i was driving on christmas and my car just turned off as i was getting on the freeway onramp. and the piece connecting the throttle lever to the carburetor came off too and i had no gas pedal. so i hooked that back up and tried to start it again but no luck. its cranking but wont start, so i tried starter flui in the carb, didnt work. then i tried turning the key on and spinning the fan, while i had a multimeter on the coil, it went to 12v and then to 0 as its spose to so i beleive the points and condenser are ok yea? so then i pulled the middle wire from the dist coming from the coil and put it near a ground and when i cranked it, it sparked, so i pulled the first spark plug wire and tried to crank it and i got a spark the first time, then i tried again and again and no spark, so i tried plug 2 and no spark either, i just replaced the cap and rotor which appeared to be good and its still cranking but not starting and im still not getting a spark. any ideas? can i pull a spark plug out and crank it and see if it sparks or will i screw something up? and should i not try pumping the gas? because i pumped it a buncha times trying to start it already.
64 chevy nova 194 straight 6 thanks. Last edited by typeblu; 12-27-2005 at 11:40 PM. |
Re: no spark?
what year is this car/ motor? You say it's got a points ignition?
Re: Re: no spark?
i dont get how theres a charge goin in the cap but no spark coming out, just replaced cap and rotor ;\ i got it to spark ONCE! |
Re: no spark?
I'd say either the plugs got wet, or you have some arcing going on inside the dist. cap.
2007 Certified DaimlerChrysler Service Technician... True blue GM at heart. |
Re: Re: no spark?
Re: no spark?
So your pulling the wires off of the plug, and testing for spark. Where are you holding the plugwire to test it? Something grounded, i hope. Remember, even new parts can be bad.....
EDIT: You can pull the plugs out to test for spark, and I'd recommend doing so.
Re: no spark?
how far the points open has alot to do with how much energy the spark has.
and the condensor could be bad |
Re: Re: no spark?
Re: no spark?
If your coil wire is firing, but the plug wires aren't, you've either got a bad distributor cap or a bad rotor..
Re: Re: no spark?
Re: no spark?
i jsut had another idea. i had someone tell me i had a tail light out the other day, and then i also had a blinker go out too, i checked the fuses under the driver side dash and theres like 8 of them and they were all good, i replaced the blinker but not the tail light. i beleive both blinkers work fine now but the tail light is still out, can that cause me to lose spark?
Re: no spark?
k so when i got home i pulled a spark plug and plugged it into the wire and cranked it, no spark at all. i think i got a weak charge coming out of the coil cause the coil lead when put by a ground doesnt make that big of a spark. i changed the taillight and light fuse and the tail lights work fine now. the front blinker still doesnt work though.
Re: no spark?
Hm, i'd say now is a good time to clean, readjust and/or replace the points, condensor and lubricating pad. Since you've stated you have 12 volts at the coil, but weak fire at the plug wire, this indicates a bad condenser, points or maybe even the coil itself. Do you have another coil handy to test with? BTW, blown running lights can't cause a no fire condition.
EDIT: Your points should be 0.019in apart while fully open..
