Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 12-27-2005, 10:25 PM
timd timd is offline
rear defogger
I have 12 volts between the two power plugs on each side of the rear glass but the rear defogger doesn't work. What should the resistance be between the two connectors with the power plugs disconnected?
Old 12-27-2005, 10:36 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: rear defogger
Just check resistance with an ohmmeter. If you have a damaged grid, it should show an open circuit.
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 12-28-2005, 06:25 AM
e2helper e2helper is offline
Re: rear defogger
Resistance of a rear defog grid will be well under 1 ohm. Typically those things draw 20-30 Amps and since your vehicle runs at 12-14 volts.....well you can do the math
Old 12-28-2005, 10:46 AM
Thanks to all. I was reading continuity thru the grid but it was well above 1 ohm (hundreds) and wasn't sure what it normally should be. I'll check further and report here what I find.
