Old 12-27-2005, 08:34 PM
collegekid collegekid is offline
Question catalytic converter
I am a college football player for small college NAIA, limited amount of funds. I have a problem on my 97 3.8 firebird with my catalytic converter being stopped up can't afford a new one. Don't have to worry about emissions check in the small town I live in. Someone told me just to cut it out and replace with straight pipe to the muffler. Will this mess up the computer system on the car?
thanks for your help.
Old 12-27-2005, 10:55 PM
ROUDA's Avatar
ROUDA ROUDA is offline
Re: catalytic converter
The 3.8 97 Firebird Has 2 Cats. I Think There Are O2 Sensers After The Cat. So If You Take The Cat Out I Dont Know What You Would Do With Them. But If Anything You Could Just Hollow Them(cats) Out.
Old 12-27-2005, 11:11 PM
importeater38's Avatar
importeater38 importeater38 is offline
Send a message via Yahoo to importeater38
Re: Re: catalytic converter
does it really? i thought that was just for v-8s?
93 trans am hurst shifter and zo6 rims. 94 trans am GT. functional ram air hood w/k&n air box, ROH rims, toyo skins, Borla cat back SS, TB bypass, de-screened MAF, BBK underdrive pully, Mieziere electric water pump, spec stage III clutch. '06 Yukon Denali XL, black, loaded. http://www.cardomain.com/ride/711131
Old 12-28-2005, 10:55 AM
ROUDA's Avatar
In The Middle Of 1995 They Put The 3.8 Out . It Was Made In California For Emmisions. With 2 Cats , Also Give It Less Back Pressure More Power.
Old 12-29-2005, 05:02 AM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
basically, if you didnt get what rouda said..
take the cats out..
shove a pipe through them until you can go freely to the other side...shake all the crap in there out..
install,
drive.
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 01-03-2006, 10:31 AM
Helmuth48's Avatar
Helmuth48 Helmuth48 is offline
How do you know it is stopped up??? ....pressure check ??? or test pipe ???
Old 01-05-2006, 08:36 PM
79Bandit's Avatar
79Bandit 79Bandit is offline
or you can do what i did and for about 20 dollars buy a "test" pipe wich is just a hollow catalytic converter and bolts right on where the stock one did. probally could find them cheap on ebay. but for free you could just hollow out the ones on there now. just scrap all around untill you can see threw them.
Old 01-06-2006, 11:07 AM
frizbal frizbal is offline
Send a message via MSN to frizbal Send a message via Yahoo to frizbal
You say in 1995 they started putting 2 cats on the 3.8? I have a 96 3.8 and i have one cat with an o2 in front and behind of it.........
Old 01-06-2006, 11:09 AM
Re: Re: Re: catalytic converter
Why would you go through all the trouble to get a hollow bolt on? or hollow out the existing cat? Wouldn't a straight pipe do the same thing? or is for back pressure..... or emissions test?..........im just tryin to get some info for mine cuz i want to take off mine but dont know if it will mess with the back pressure
Old 01-06-2006, 05:22 PM
tg1hq's Avatar
tg1hq tg1hq is offline
OK, I was going to "gut my cats" but someone told me it was going to screw up performance. I thought it would help. Does it have something to do withthe location of the O2 sensor?
Old 01-06-2006, 09:24 PM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
It has to do with the o2 sensor itself. If you empty out the cats, the sensor(s) after the cats will give different readings, causing your car to run differently and show a check engine light. There are dummy sensors available to trick the computer into thinking it has cats on the exhaust, dig around a little they should be easy to find.
Rusting out Honda Civic $900
Fart cannon muffler: $300
Assorted stickers advertising products you'll never own: $50
Having your @ss handed to you by a brick shaped suv: Priceless.
Yup, I own the suv.
Old 01-07-2006, 09:47 PM
97formulaws6 97formulaws6 is offline
Cutouts
Hey I've got a 97 WS.6 and was wanting an exhaust cutout kit cause i think that the idea of running open manifolds or through my whole system with the flick of a switch is cool. Anybody out there know a good brand, type, etc...also I'm thinkin' that I only need one 3" cutout since the birds that year aren't true dual. Any advice/testimonials welcome please.......
http://www.cardomain.com/ride/2120781
Old 01-08-2006, 01:06 PM
If i got a hi flow cat... would it mess with the o2 sensors? or would it still throw the c/e light?
